Voice Gateway- FXO ports configuration
Hello Everyone,
Need some urgent help form Voice Experts please reply.
1. I have two fxo ports configured, one is for IVR and another is direct line on one cisco IP Phone and i used the commad connection plar for it.
    when i call from outside the call is forwarded to specific number (ex 1246) that is configured for direct line but when i disconnect the line from outside         call is infinitely ringing on IP Phone. I am unable to understand what setting it require.
voice-port 0/1/1
cptone SA
timeouts ringing 5
connection plar 1246
caller-id enable
2. As two FXO ports are configured one for direct line and another for IVR. I want to dedicate port 0/1/1 only for direct line for inbound and outbound calls. But when i dial the external call from any of the IP Phone it will pick either voice port 0/1/0 or 0/1/1 based on availability. I want to restrict port 0/1/1 only for direct line on only 1 IP Phone no other phones should use this FXO line.
3. When i call any number from outside IVR or Direct line and disconnect the line and dial again soon after disconnection. Gateway does not release the call for around 2 minutes. Even though there is no Inbound or Outbound call but still it show line busy signal.
Please Advice on the above issues.
I have attached the config file. Voice gateway is 2951 and Call Manager version is 8.6 (only one server as publisher), IP phone model is 7962
For problem 1 and 3 try to study this doc:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
This is my FXO config, it works right:
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone UAE-CUSTOM-ALCATEL
dualtone disconnect
  frequency 425
  cadence 375 375
voice-port 2/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-ALCATEL
input gain -2
output attenuation 0
no non-linear
no vad
playout-delay nominal 100
playout-delay mode fixed
cptone IT
timeouts interdigit 5
timeouts call-disconnect 1
timeouts wait-release 1
timing guard-out 300
connection plar opx 510
description use LOOP_START
For the problem 2 tou can try to configure a COR list. Try to see this other doc:
https://supportforums.cisco.com/thread/2159413
Regards.
Hello Daniel
the voice port command what you have give is not working it's gives fast busy  line , you are customizing for you UAE why you are putting cpton  for Italy
Hi Dris,
Can you please describe your problem.
