VOICE GATEWAY TROUBLESHOOTING
SOLID
Hello All, One of my customers recently reported their inability to make outbound calls. The ISP has been contacted, and they have been insisting there's a loopback on the router, but I have logged on to the router and there is no loopback.
22 Replies 22
That is just a part of the configuration page, please provide the entire configuration of the port.
Response Signature
Hi Rodger
this is the complete config  on the port.
As you can see your gateway registration is in an unknown status so we need to dig more.
Please post the output of the following commands:
show ccm-manager
show mgcp
debug issn q921
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dear Carlo,
RST-HQ#
SRST-HQ#debug isdn q921
debug isdn q921 is ON.
SRST-HQ#
The last command should have been debug isdn q921 and you also need to turn on terminal monitor to see the output in the terminal window.
Response Signature
Yes i know,
SRST-HQ#
SRST-HQ#
Mohammed-A.R.A
Why its showing in below output as Primary CCM Down, Secondary CCM Down?
Should it not show call manager FQDN/IP?
Is source address properly defined and ISDN bind L3 command exists.
Can you share all serial port configuration, show run int serial followed by respective port numbers
SRST-HQ#show ccm-manager
MGCP Domain Name: SRST-HQ.nig.mmo.heiway.net
Priority Status Host
Primary Down mmosnighcsub.ng1.heiway.net (10.196.8.7)
First Backup Down mmosnigotcsub.ng1.heiway.net (10.196.10.7)
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Mohammed-A.R.A
Try changing clock source to primary
You would have to reboot it or do a "no mgcp", "mgcp" to reset the gateway.
