%VOICE_IEC-3-GW: CCAPI
shahnawaz.a
We are running with a problem with MGCP gateway getting following error
and the issue is one way audio is not there 1 out of 10 calls, ios version is 12.24T.
Please let me know if anyone has any answer for this
Shahnawaz
6 Replies 6
Ayodeji Okanlawon
shahnawaz,
IEC represents internal error codes. Ecah IEC has its own description. What you have povided is missing the IEC error description itself...Something like this..
Please provide the full error description...
Oct 14 17:13:21.534:%VOICE_IEC-3-GW:CCAPI:Internal Error (Trunk-group select
fail):IEC=1.1.182.1.23.8 on callID 62 GUID=11C79B82DECF11D68044C61A8D4F75E3
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Her is the following error
103064: Feb 27 06:55:05.156 UTC: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID -1
103065: Feb 27 06:55:09.120 UTC: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID -1
103066: Feb 27 06:55:10.136 UTC: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID -1
103067: Feb 27 06:55:13.548 UTC: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID -1
103068: Feb 27 06:55:14.260 UTC: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID -1
103069: Feb 27 06:55:14.556 UTC: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID -1
Please let me know the same.
Hi, sorry for the late reply
Please type this command and you will get the description of the iec..
show voice iec description 1.1.180.1.13.114
Send the output here
Please find below the output.
ae_difc_gwb#sh voice iec description 1.1.180.1.13.114
IEC Version: 1
Entity: 1 (Gateway)
Category: 180 (Software Error)
Subsystem: 1 (CCAPI)
Error: 13 (Software Error)
Diagnostic Code: 114
Waiting for your reply
I will suggest that you upgrade your IOS. This looks like an ios error..Try and upgrade your IOS and se eif the problem goes away
If you're here, run:
sh voice dsp group all
You may see below. Notice the state. State: should be UP.
dsp 1:
  State: APP_DNLDING, firmware: 28.3.1
  Max signal/voice channel: 32/32
  Max credits: 480, Voice credits: 480, Video credits: 0
  num_of_sig_chnls_allocated: 23
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 480, reserved credits: 0
    Signaling channels allocated: 23
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 2:
  num_of_sig_chnls_allocated: 0
    Shared credits: 96, reserved credits: 0
    Signaling channels allocated: 0
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 384
    Codec: CONF_G722, maximum participants: 8
    Sessions per dsp: 5
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
Reload the router as a workaround.
You'll need to upgrade the IOS to fix this issue.
