Voice ISDN BRI - INS64 - Outbound issue
mikezul
Hi all,
Having a bit of problem in configuring INS64/BRI for 1 of our office in Japan.
Topology is simple, HQ CUCM -MGCP- ISR4351 -BRI- NTT ONU/Device
Call control is MGCP, and established
ISDN to NTT device is good, MULTIPLE_FRAME_ESTABLISHED
Inbound is not a problem.
However, outbound is rejected immediately, tested many digit manipulation and still failed.
Anyone knows what this error means? *yes, checked google and ISDN codes but not very helpful.
002921: Jun 27 09:59:12.276: ISDN BR0/3/0:0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x82D8 - Incompatible destination
Progress Ind i = 0x8283 - Origination address is non-ISDN
This was a PBX migration so if I connect it back to the PBX, it would work.
Appreciate any help I can get.
MZ
002920: Jun XX 09:59:12.231: ISDN BR0/3/0:0 Q931: TX -> SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x4181, '050XXXXXXXX'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0x80, '117'
Plan:Unknown, Type:Unknown
Brandon Buffin
Get the telco involved and troubleshoot with them. Is 117 a valid number - looks like this is the called party number. Make sure plan/type are what the telco is expecting. Do you have details on the PBX configuration to check digit manipulation for outbound calls, plan/type configuration, etc.?
Brandon
Thanks for replying.
Yes, 117 is a valid destination, it's something like time announcement.
It's working in our other office with INS1500/PRI circuit to the same carrier.
So issue also happen in all outbound call and this is just example.
I don't have access to the PBX, unfortunately, which is the painful part.
I tested the usual digit manipulation, i.e. include area code, last 4 digit, E164, numbers only, add prefix 9, plan type subscriber, unknown, all kind of thing I can imagine..
Any idea from the error or any debug which can be done to see what's the expected number?
Thanks.
Best option is to get on a call with the carrier, perform a test call and see what they are seeing. They should be able to tell you why you are receiving the error.
