IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5629 Views
  • 14 replies
So I understand that an eToken is requried in order to do any security in Cisco UCM (phones, voice ports).  Is there any alternatives without using eTokens?If the eTokens are required do we HAVE to use the Cisco USB eTokens (i believe the part number...
ryabutler by Level 1
  • 1028 Views
  • 4 replies
Hi Team, Please let me know is there an update to do Call recording for Cisco ATA 190 & 191, when it is connected to CUCM and CME.1. How to do Call recording if Cisco ATA is connected to CUCM ?2. How to do Call recording if Cisco ATA is connected to ...
CommSouth by Level 1
  • 957 Views
  • 2 replies
Greetings - As part of an in-progress CUCM 12.5 setup, I've setup and run LDAP synchronization with our AD.I'd like to know how I can undo the LDAP synch and start over from scratch. I believe I can delete the existing search bases (I'm using eight),...
pdx99 by Level 1
  • 1291 Views
  • 5 replies
Good morning - We just recently started receiving this error a couple of days ago. Nothing in the environment changed, but the directory simply stopped working. What is even more odd is that my phone (8865) could browse the directory yesterday but it...
Joel Fox by Level 1
  • 1205 Views
  • 7 replies
Dears,i have a below UCS M3 server BOQ in which it has E5-2643 CPU  running 11.5 version of CUCM,, hence the supported hardware link only shows M5 hardware, this server was purchased for 9.1 and it has been upgraded to 11.5 since from past 1 year i d...
adamgibs7 by Level 6
  • 1215 Views
  • 12 replies
