Voice-Port command is not recognizing in Cisco 4321 Router
Yenosh
I am trying to configure the FXO port in cisco 4321router but the command voice-port in not recognizing. It is always throwing error
I have Latest Software Version: 16.06.01
NAME: "NIM subslot 0/2", DESCR: "NIM-2FXO Voice Analog Module"
PID: NIM-2FXO , VID: V02 , SN: XXXXXXX
I have seen this on router, is it creating any problem
voice-card 0
no dspfarm
Do I need to activate anything to get this work
2 Accepted Solutions
Per your shared output the UC service license is not in use, very likely because you have not accepted the EULA.
StoreIndex: 1 Feature: uck9 Version: 1.0
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
Try with this
license accept end user agreement
license boot level uck9
Then reboot the router.
Response Signature
Hi Roger,
Sorry for the delay in reply!!!
License State: Active, Not in Use, EULA not accepted, yes it is in not use state. That is created the problem.
Below Two commands fixed my issue.
license right-to-use move uck9
6 Replies 6
Number 1: Do you have the license activated for UC services on the gateway?
Number 2: That’s far from the latest version of IOS for that particular model of router. If I’m not wrong it would be 17.7 something.
Response Signature
1) Yes license activated for UC services on the gateway
2) Software version above 3.X should support voice commands, and all other site routers are having same software version.
Please share the output from sh license all. My comment on the version had noting to do with if the commands would or would not be present, just an observation that you're not using the latest version as you stated in your original post.
Response Signature
Please find the licence details
License Store: Primary License Storage
StoreIndex: 0 Feature: ipbasek9 Version: 1.0
License Type: Permanent
License State: Active, In Use
License Priority: Medium
License Store: Built-In License Storage
StoreIndex: 0 Feature: appxk9 Version: 1.0
StoreIndex: 2 Feature: securityk9 Version: 1.0
StoreIndex: 3 Feature: FoundationSuiteK9 Version: 1.0
StoreIndex: 4 Feature: AdvUCSuiteK9 Version: 1.0
StoreIndex: 5 Feature: cme-srst Version: 1.0
License Count: 0/0 (In-use/Violation)
StoreIndex: 6 Feature: throughput Version: 1.0
Try with this
Response Signature
Hi Roger,
