IP Telephony and Phones
Labels
Hello Community, Does anyone know what Error CJ:2100:2 denotes? Is there available any list of codes with explanation that includes 2100?   CUCM v11, Jabber for Windows v12 IM&P works, Telephony Services Connection to Phone dont work.Attached is the ...
Wanting to setup call forward to multiple number, one extension at a time. What I mean is, I want the call to forward to another number if no answer, then to another number if the forward doesn't answer. Example: Call comes into 3000. No answer so, c...
jadkins01 by Level 1
  • 1407 Views
  • 2 replies
Hi I know that the Cisco 4000 ISR can be configured as a CUBE to support SIP REC recording.My question is whether I can also use SIP REC for recording if I install 72-port FXS on this ISR?Whether CUBE will also send the audio of the analog interface ...
bo liu by Level 4
  • 379 Views
  • 1 replies
Hello All, CUCM System version: 12.5.1.13900-152   - 1 Publisher and 3 subscribersI'm having an issue where NTP is unsynchronized. I can sit and use utils ntp restart on the publisher all day long and it never synchronizes. remote refid st t when pol...
bwolf by Level 1
  • 29458 Views
  • 40 replies
  • 5 Helpful votes
When I get routed to a specific user mailbox from an internal number, the greeting plays followed by a message that says the mailbox is full so I can't leave a message.If I call it from an external number (my cell) I can leave a message.In reality, t...
