Voice-ports not showing up on ISR router
Sean McQuade
Level 5
Level 5
Hi all,
I have a 2951ISR and have installed two PVDM3-32 modules into it. I have installed the UC license and but cannot get enter any of the voice-port commands and get the following:
Router(config)#voice-port 0/0/0:15
% Invalid input detected at '^' marker.
The hardware all shows up in the show diag:
Slot 0:
        C2951 Mother board 3GE, integrated VPN and 4W Port adapter, 4 ports
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Hardware Revision        : 1.0
        PVDM Slot 1:
        WIC Slot 0:
        VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
But under show voice port summary and show voice dsps, the output is blank:
Router#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
PWR FAILOVER PORT        PSTN FAILOVER PORT
Router#show voice dsp
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
                           *DSP SIGNALING CHANNELS*
I only have a very basic config on the router for testing:
Router#show run
Building configuration...
Current configuration : 2299 bytes
! Last configuration change at 12:36:08 UTC Fri Nov 2 2012
version 15.2
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip cef
isdn switch-type primary-net5
voice-card 0
dspfarm
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
license udi pid CISCO2951/K9 sn FTX1639AN8P
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
hw-module sm 2
redundancy
controller E1 0/0/0
interface Embedded-Service-Engine0/0
no ip address
service-module enable
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface SM1/0
no ip address
shutdown
!Application: Restarted at Fri Nov  2 12:21:40 2012
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface SM2/0
no ip address
shutdown
!Application: Restarted at Fri Nov  2 12:21:33 2012
interface SM2/1
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
And I have verified the licensing:
Router#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
Could this be a hardware issue or have I configured something incorrectly?
Many thanks
Sean
2 Accepted Solutions
allan.thomas
Level 8
Level 8
Hi Sean,
You need to create the pri-group under the controller in order to create the logical voice-port.
Allan
You need to configure your PRI and change the controller into a voice port.
Isdn switch-type primary-ni
Controller t1 0/0/0
pri-group timeslots 1-24
allan.thomas
Level 8
Level 8
Hi Sean,
Allan
Controller t1 0/0/0
D'oh! I had the timeslots in earlier and then had to reboot the router and obviously didn't save it, so have been trying to fix a problem that wasn't there! Many thanks for pointing out my stupidity!
Hi Sean,
D'oh indeed, it always turns out to be the simplest of things at times which we often overlook. Cheers for the rating, and for the record 'copy run start'. :-)
Allan.
