Voice Pri crackling
jgranda
Cisco 2821 with dual Vwic T1 card
Having a probkem with two PRI circuit the voice crakling. Both circuit are running error free. Do the following
1) replace the Dual Vwic card same issue
2) Replaced three DSP cards
3) change the slot from 1 to 3
All internal calls no issues. Only calls that are coming through the both PRI get the crakling. The phone company has tested the circuit ans is poing to the equipment. Can I get any recomendation what to test next.
Jose
16 Replies 16
dino55088
Can you paste  controller T1 and voice card related config and show controller t1.
did you setup master clock on of the t1 using network-clock-select ?
Here is the inforamtion you requested
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
network-clock-select 2 T1 0/3/1
controller T1 0/3/0
cablelength long 0db
pri-group timeslots 1-24
description voice-local-PSTN
controller T1 0/3/1
description voice-ld-PSTN
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn incoming-voice voice
no cdp enable
interface Serial0/3/1:23
no ip address
encapsulation hdlc
no cdp enable
dial-peer voice 1 pots
description PSTN Inbound
translation-profile incoming pstn-inbound
service cvp-survivability
incoming called-number 2200
direct-inward-dial
port 0/3/0:23
dial-peer voice 5 pots
description TF-800 Outbound
destination-pattern 81800.......
port 0/3/0:23
forward-digits 11
dial-peer voice 6 pots
description TF-866 Outbound
destination-pattern 81866.......
port 0/3/0:23
forward-digits 11
dial-peer voice 7 pots
description TF-877 Outbound
destination-pattern 81877.......
port 0/3/0:23
forward-digits 11
dial-peer voice 8 pots
description TF-888 Outbound
destination-pattern 81888.......
port 0/3/0:23
forward-digits 11
dial-peer voice 9 pots
description 911 Outbound
destination-pattern 911
port 0/3/0:23
forward-digits 3
dial-peer voice 11 pots
description Services Outbound
destination-pattern 8[4,6,7]11
forward-digits 3
dial-peer voice 12 pots
description Local Outbound
destination-pattern 8210[2-9]......
port 0/3/0:23
forward-digits 10
Let me know if this help or you need teh complete configuration
Can you please post the output of a show controller T1?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo, here is the information
                         T1 0/3/0 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
  Description: voice-local-PSTN Windstream CKT ID 31HCGS700854SW Account 534096
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (255 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 64 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
T1 0/3/1 is UP.
  Description: voice-ld-PSTN
  Transmitter is sending remote alarm.
  Receiver has loss of frame.
  Data in current interval (257 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 257 Unavail Secs
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail ecs
The phone company have said the circuits are okay.
I appreciate the help.
Regard,
Jose
Hi Jose,
Yes circuits are ok.
Let's check DSP.
please share the output of a show voice dsp group all.
Did you try to reload the gateway?
Please let me know
Carlo
Carlo, The router has been reset. The DSP module have been replaced. Here is  the output.
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 26.3.6
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 0
    Credits used (rounded-up): 0
dsp 2:
  Max credits: 240
dsp 3:
  Max credits: 240
dsp 4:
  Max credits: 240
  num_of_sig_chnls_allocated: 6
    Signaling channels allocated: 6
dsp 5:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
    Signaling channels allocated: 0
dsp 6:
  Max credits: 240
dsp 7:
  Max credits: 240
dsp 8:
  Max credits: 240
dsp 9:
  Max credits: 240
dsp 10:
  Max credits: 240
dsp 11:
  Max credits: 240
dsp 12:
  Max credits: 240
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
0 DSP resource allocation failure
Regrads,
Jose
Here is the information you requested
VGW-SANANTONIO-3770#show voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x3AD 1A8C 0x49D45F80 0/3/0:23.23 0/1:1 *7864720345 g711ulaw 190/3
1 active call found
See attached
Jose
On voice port 0/3/0:23 and 0/3/1:23 add
bearer-cap speech
compand-type ulaw
Let me know
Carlo
I added the options still gtting the crackling.
Jose
Hey,
15.1(4)MX is the latest available version for 2800/3800 series routers. An IOS upgrade and hence DSPware upgrade is no go.
You'll definitively need a PCM capture to isolate what the source of the craking noise is:
voice hpi capture buffer 1000000
voice hpi capture destination flash:pcm.dat
Once you have configured the above, make the test call and look for the
voice-port channel that the call comes in on. For instance, if the call
comes in on the voice-port X/Y/Z then you will need to execute the following
exec level command:
test voice port X/Y/Z pcm-dump caplog 7
Once the capture is complete, make sure to disable the capture by executing
the following:
test voice port X/Y/Z pcm-dump disable
Also get into the config mode and disable the two commands that you had
configured before:
no voice hpi capture buffer 1000000
no voice hpi capture destination flash:pcm.dat
Get the PCM capture so we can decode the audio.
~jorge
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
I will have the Capture by today. i appreciate all the help.
Jose
Can you tell me how to load the PCM.dat so you can decoded. The location is not letting attach it,
Jose Luis Granda
Here is the PCM file if you can tell me what can be the issue.
Jose
Jorge will you have time to decode the PCM. Let me know I am having issue with the crackling and not able to find the issue.
Thanks for the help
Jose
