Hello, My local jabber is not registering and I realized that Cisco UDS service does not comes up.. only in starting status. Can you guys suggest something? I am following the tshoot link: Troubleshoot Jabber Log in Problems - Cisco Thanks.
I am trying to register a CP-8945 VoiP phone. I have filled in all the information needed and added a line group. The display is showing the information but it's still showing unregistered on the CUCM. I'm not sure what I missed. Please help. Th...
Hi, Greetings, Currently working out with Cisco IP Phone 8851 and 8832 however got stuck with this prompt message. Is there someone here who can help us to go through?
What is the max number of people that CUCM 14 would support on a multiway conference call?
I have a CP-8945 VoiP phone that was previously used. I was able to change all the information for a new End User. I'm able to ping and type in the IP address and it is registered on the CUCM but it still shows "Registration in progress." Any idea...
Hello, it became necessary to turn on call forwarding at the reception area, where all the landline phone calls are being received. When the phone calls are being forwarded to the mobile, all calls arriving at the landline number are being dropped. I...
Hi, What are the firewall required ports for wifi-calling?I've found old article that stated: UDP ports 500, 4500, and TCP 143 ports but not sure if there are all ports that need to be allowedWe have restricted internet breakout for the visitors wlan...
Hello,Please kindly help, when cloning Cisco Expressway-E and Expressway-C on VM level via Vmotion , these cloned (C, E) server's serials were changed in new UCS server. As I know, Exp C and E licenses are bind with serial number I do not want to fac...
Hi How we can enable third party SIP for Auto Answer, Pickup and Forward [ALL/No Answer/Busy] while it is registered to call manager I think it is doable with VG and CME with FAC Thanks
Hello Everyone, My Customer has a CME installed under Cisco ISR 4431, this router contains two interfaces BRI, we have configured the all the Features, everything work properly, one single point, is when we make a call from PSTN to Internal using BRI...
Hi teams, i have a case for ATA 191. This ATA is new. i just enable web access for this ATA, and never make new password. Default password should be admin/admin, cisco/cisco. but does not work. Firmware ATA: ATA191.12-0-1-0405-005and then i try cha...
Hi, We are trying to setup an 8865 phone with 8865 KEM (dual screen, 14 buttons, 2 pages), however, the module does not seem to be coming up. At one stage, we received an alert stating "Accessory Added: The phone is not setup for the expansion modu...
Hello Cisco Community. I have a question and hopefully someone has the answer. I have a customer who has a sip trunk configured to a system that receives calls and routes them to certain destinations, having this connection as a sip trunk makes it wh...
I have fax machines setup on a VG310 and they are able to fax internally between each other with no issues. When I try to send a fax externally I get a "Line Busy" error on the fax machine. Inbound faxes don't seem to come in. I cannot seem to fin...
Hi Which certificates to take care to renew during operation Thanks
| Subject | Author | Posted |
| 10-17-2025 09:01 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 4 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
