Voice quality issue - is there a checklist to follow
ad27singh
Hi All,
I'm trying to learn if we can have some defined path to follow when trying to troubleshoot "random"  voice quality issue - echo/underwater sounds | call drops. Is there a sequence of things which should be checked when dealing with such issues.
Like check
1.ping round trip time
2.ping hop to hop
Also can a wireshark capture help isolate the issue ?
what all we should be checking in the wireshark captures for voice quality issue ?
or any other free tools which can be used for isolating such issues as we know if there is a vocie quality issue it be related to mostly packet loss or drop. This is my understanding and it be great to hear from everyone what all check they do when faced such issues.
I'm quite new to the concepts so bear with my knowledge and understanding of the things.
Manish Gogna
Some good docs below specific to voice quality troubleshooting
https://supportforums.cisco.com/document/101961/how-troubleshoot-voice-quality-issues-ucm-environment-bad-sound-no-audio
http://www.cisco.com/c/en/us/support/docs/voice/voice-quality/30141-symptoms.html
http://www.cisco.com/c/en/us/tech/voice/voice-quality/tsd-technology-support-troubleshooting-technotes-list.html
Manish
Thanks Manish...really helpful documents with very useful commands.
I have one more question how can IP SLA help in the voice network with jitter issue ?
You can check IP SLA config, features and limitations related information here
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book/sla_udp_jitter_voip.html
Manish
- Do rate helpful posts -
