voice register monitoring using CP7915
nallan987
First some data on my hardware:
  1. Our reception phone is a Cisco 7942 and it has a CP7915 expansion unit attached. This expansion unit is set up and working. This unit is configured as ephone dn and ephone.
  2. Our desk phones are Cisco CP-7821 handsets. They are configured as voice register dn and voice register pool.
I am trying to get the CP7915 module to monitor the voice register extensions but it seems that you can only add ephone dn's to it. Is it possible to have the CP7915 module monitor voice register lines or am I wasting my time? I am basically just learning and have no real training on this so if I have some of the nomenclature incorrect l apologise in advance.
Thank you.
Please post your iOS version and platform.
Also attach your actual config
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlos thanks for the reply. I am running 15.4 on a Cisco 3925.
which part(s) of the config did you want to see specifically?
Hi.
the output of a show run | s voice register and a show run | s ephone would be enough.
Cheers
Carlo
Hi.
On your config add these lines if not present.
conf t
presence
max-subcription 100
allow subscribe
presence call-list (to add presence on missed/received/placed calls
under voice register dn X
add
allow  watch
Carlo
