IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5891 Views
  • 14 replies
I need a good 3rd party app for CDR that can has an easy to navigate portal or dashboard and that can be used to schedule reports and send them via email to necessary people. I also need support for multiple cluster reporting in the same app.  Does a...
We migrated a 7.15 Cluster to 9.1(2) with 5 subscribers.  When we make changes to phones that were migrated, the changes don't take effect.  If we create new IP Phones, we can make any type of change and things work perfectly.One weird fact about cha...
mzajeski by Level 1
  • 710 Views
  • 4 replies
Hi All ,I read through the CCM SDI logs. Just want to know some info on CCM traces on acadamic purposes.Below lines are from sdi traces of SIP trunk call.23:30:57.392 |DET-MediaExchange-(95)::fillAudioMediaInfo, partyIdx=0, xferMode=16, codec=15, max...
