ā10-14-2013 06:48 AM - edited ā03-16-2019 07:52 PM
Hello. I have a number
221113331114444
What rule I could use to change any 111 to 777? The result should be:
227773337774444
Simple rule
rule 1 /111/ /777/
makes
227773331114444
The rule change 111 to 777 only once(((
Please help.
Solved! Go to Solution.
ā10-14-2013 07:39 AM
rule 1 /111\(.*\)111/ /777\1777/
Kind regards,
Andrew C.
Kind regards,
Andrew C.
ā10-15-2013 03:32 AM
Thanks. That works!
