09-12-2011 12:39 AM - edited 03-16-2019 06:56 AM
Hi All,
Can someone direct me to a good source which describes voice translation rules, or help me understand the following rules:
voice translation-rule 1
rule 1 /90/ /0/
voice translation-rule 2
rule 1 /^\(5\)\(.*\)/ /\2/
voice translation-rule 3
rule 1 /^26\(....\)/ /\1/
voice translation-rule 4
rule 1 /.*/ /8208/
voice translation-rule 5
voice translation-rule 6
rule 1 /^\(.*\)/ /7\1/
voice translation-rule 9
rule 1 /^999$/ /999/
rule 2 /^9\(.*\)/ /\1/
Thank you in advance .
Paul
Solved! Go to Solution.
09-12-2011 12:50 AM
Here's a good guide:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
As for the rules, the first part is what to match, the second is what to translate to.
rule 1: match 90 anywhere change it to 0.
rule 2: begins with 5 then one or more digits remove the 5 (\2 means set two which is denoted which is the second () "\(.*\)" the () have to be escaped with \)
rule 3: begins with 26 then 4 digits, keep only the 4 digits after 26.
The rest are pretty much the same, except rule1 of translation-rule 9, the first party does nothing, starts with 999 and then no more digits ($ means the end of string) translate it to 999. Rule 2 just removes the 9 from a number begining with 9.
09-12-2011 12:56 AM
Hi Paul
You need to read the bellow document to understand the logic first
And the above translations do then bellow in brief:
1- if a number comes with 90 the will replace it with 0
2-if the number start with 5 the 5 will be striped and the rest will remain
3-if the number start with 26 the 26 will be removed and the rest will remain
4-any number to be replaced with 8208
5- same as 3above
6- prefix 7 to the original number
9- first one if the number is 999 leave as 999 if it is any other number start with 9 remove the 9 and keep th rest
I wish i was accurate in all of them :)
If helpful rate
09-12-2011 12:50 AM
09-12-2011 12:56 AM
Hi Paul
5- same as 3above
If helpful rate
09-12-2011 06:52 PM
I wish we answered your question !, if yes please rate it as resolved
