Hi there,
Hoping to find some answers here. I have two VoIP ata's for 4 sip accounts. one of them is a Cisco SPA122, the other one a Linksys PAP2. This problem is on both of them, that's why I think the problem is in the settings as they are the same on both of them. Calling en being called works fine. But after a while the call is disconnected. the time this happens is variable. Can be after 2 minutes, can also be after 20 minutes,
Any idea which setting can cause this? I tested the VoIP sips on a smartphone app, no problems there.
Please let me know if you need more information about my setup.
Thanks!
