voip cannot connect
Yuliang Liang
top :
---------------LOCAL:780....------------------------------------------------------------------------REMOTE:730....-------
(8000)voice-phone1---PBX-(PRI)-----(T1/E1 card)-2911--------3845-(e1)----PBX---voice-phone2(7000)
i use csim start 808000 in 2911 ,the voice-phone1 was ring up.but I use csim start 808000 in 3845 ,the voice-phone1 did not ring up.
i use csim start 808000 in 3845 ,it display :
csim start 808000
csim: called number = 808000, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(343371)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
in 2911 it display:
Nov 12 05:33:08.205: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
Nov 12 05:33:08.209: //68/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
Nov 12 05:33:08.209: //-1/04745578B1D6/CCAPI/cc_api_call_setup_ind_common:
   Interface Type=0, Protocol=1
   After Number Translation Checking:
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=808000(TON=Unknown, NPI=Unknown)
Nov 12 05:33:08.209: //68/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
Nov 12 05:33:08.209: //68/04745578B1D6/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=68
Nov 12 05:33:08.209: //68/xxxxxxxxxxxx/CCAPI/cc_set_extended_caps:
   Caps=0x315AF628
Nov 12 05:33:08.209: //68/04745578B1D6/CCAPI/cc_incr_if_call_volume:
   Remote IP Address
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
Nov 12 05:33:08.209: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=808000, Call Transfer Consult Id=
   No Matching Node
Nov 12 05:33:08.209: //68/04745578B1D6/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=TRUE)
   Cause Value=21, Call Entry(Disconnect Cause=0)
Nov 12 05:33:08.209: //68/04745578B1D6/CCAPI/cc_decr_if_call_volume:
   Remote IP Address
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
Nov 12 05:33:08.209: //68/04745578B1D6/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
Nov 12 05:33:08.209: //68/04745578B1D6/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=0
   Deleting profileTable[0x316EB0A8]
Nov 12 05:33:08.209: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
what is the problem with it
So when you do csim start 808000 on the 3845 you get the output on the 2911 GW? If that is the case it looks like you don't match any outgoing dial peer on the 2911. Could you please post your config from both VGWs and also do the following debugs.
debug voip dialpeer
debug isdn q931
Please remember to rate all useful posts.
Response Signature
