06-08-2017 12:13 AM - edited 03-18-2019 12:15 PM
Hi Team,
My requirement is to forward incoming call from external to specific extension number instead of been auto attended then forwarded to the right ext number
i.e
0768988500 should translated and call on 600 ext
0768988504 translated to and call on 604 ext
currently with the configuration below all incoming call to any of the number 07689885xx are going to ext 600
Devices installed
Current config on the Gateway router are
voice translation-rule 1
rule 1 /^.*/ /0222194600/ type unknown national plan unknown isdn
voice translation-rule 2
rule 1 /0222194600/ /600/
rule 2 /0222194695/ /695/
rule 3 /0222194/ //
voice translation-rule 3
rule 1 /^.*/ /0768988500/ type unknown national plan unknown isdn
voice translation-rule 4
rule 1 /0768988500/ /600/
rule 2 /07689885\(..\)/ /6\1/
voice translation-profile PSTN_IN
translate called 2
translate called 4
voice translation-profile PSTN_OUT
translate calling 1
translate calling 3
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 112 pots
description emergency call
destination-pattern 112
port 0/1/0:15
forward-digits 3
dial-peer voice 10 pots
description Long distance Dial peer
destination-pattern 8882........
port 0/1/0:15
forward-digits 10
dial-peer voice 3 voip
destination-pattern 6..
session protocol sipv2
session target ipv4:10.42.60.11
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 906 pots
description TIGO
destination-pattern 906[57].......
port 0/1/0:15
forward-digits 10
dial-peer voice 971 pots
description TIGO
destination-pattern 9071.......
port 0/1/0:15
forward-digits 10
dial-peer voice 978 pots
description AIRTEL
destination-pattern 90[67]8.......
port 0/1/0:15
forward-digits 10
dial-peer voice 907 pots
description VODACOM
destination-pattern 907[56].......
direct-inward-dial
port 0/1/0:15
forward-digits 10
dial-peer voice 973 pots
description TTCL-MOBILE
preference 1
destination-pattern 9073.......
port 0/1/0:15
forward-digits 10
dial-peer voice 962 pots
description HALOTEL
destination-pattern 9062.......
port 0/1/0:15
forward-digits 10
dial-peer voice 977 pots
description ZANTEL
preference 1
destination-pattern 9077.......
port 0/1/0:15
forward-digits 10
dial-peer voice 9061 pots
description TIGO
preference 1
port 0/1/0:15
forward-digits 10
dial-peer voice 9711 pots
description TIGO
preference 1
port 0/1/0:15
forward-digits 10
dial-peer voice 9781 pots
description AIRTEL
preference 1
destination-pattern 90[67]........
port 0/1/0:15
forward-digits 10
dial-peer voice 9071 pots
description VODACOM
preference 1
direct-inward-dial
port 0/1/0:15
forward-digits 10
dial-peer voice 9731 pots
port 0/1/0:15
forward-digits 10
dial-peer voice 9621 pots
description HALOTEL
preference 1
port 0/1/0:15
forward-digits 10
dial-peer voice 9771 pots
description ZANTEL
port 0/1/0:15
forward-digits 10
dial-peer voice 103 voip
dial-peer voice 11 pots
destination-pattern 902........
direct-inward-dial
port 0/0/2
forward-digits 10
dial-peer voice 10000 pots
service session
destination-pattern 9011T
dial-peer voice 1986 voip
service session
destination-pattern 900T
dial-peer voice 9014 pots
tone ringback alert-no-PI
description PSTN-INTERNATIONAL
destination-pattern 9000T
progress_ind setup enable 3
progress_ind alert enable 8
port 0/0/1
forward-digits 14
dial-peer voice 9015 pots
port 0/0/1
forward-digits 15
dial-peer voice 71 pots
preference 1
port 0/0/3
forward-digits 10
dial-peer voice 72 pots
preference 2
port 0/2/1
forward-digits 10
sip-ua
retry invite 3
timers trying 100
Solved! Go to Solution.
06-08-2017 03:01 PM
You don't have "voice translation-profile PSTN_IN" applied to anything. Apply it properly to your ports, etc.
06-08-2017 03:01 PM
