SX80 Briefing Room Design
lukeksmith
Level 4
Level 4
I am putting together a conferencing solution for a large training room similar to the one in the link below.  Can anyone please let me know what model displays are used in this design?  Is there a list of qualified displays for the SX80?
https://projectworkplace.cisco.com/assets/pdf/briefing24.pdf
Tommer Catlin
You can use any displays that are supported by the SX80.  Typically do not recommend consumer grade LCDs (from walmart, costco, best buy, etc) but commercial grade. They will have the correct refresh rates, CEC, etc.  Another great place to look is www.roomready.com.  Some nice examples there as well.
I am looking for a list of displays that are supported by the SX80. I will certainly go with commercial grade.  Thanks for the roomready link.
jon.nunley
Level 4
Level 4
You can't go wrong with Sharp professional series.  Here is a link to get you started.
http://siica.sharpusa.com/Professional-Displays/Models
Just make sure you validate it has CEC which on some of their models is referred to as Aquos Link.  You want the ability to have the codec wake the TV when a call is received or placed.
