voip dial-peer got busied out without reason
indian567
voip dial-peer get busied out despite of that the sip option ping got responses from CUCM (v8.6) within 1 second. Is there any reason for that? Or mistake in configuration?
The second problem is that once the dial-peer 1250 got busied out, the second dial-peer 1255 is not selected and the call ends
c2900-universalk9-mz.SPA.152-4.M7
CISCO2921/K9
dial-peer configuration:
dial-peer voice 1250 voip
 permission term
 description SIP server
 preference 4
 destination-pattern [2-7].......$
 monitor probe icmp-ping
 session protocol sipv2
 session target ipv4:X.X.X.200
 voice-class codec 1
 voice-class sip profiles 1000
 voice-class sip options-keepalive
 dtmf-relay rtp-nte
dial-peer voice 1255 voip
 permission term
 huntstop
 preference 5
 session target ipv4:X.X.X.72
 voice-class codec 1
 dtmf-relay rtp-nte
SIP trace:
(several same sent/received messages are exchanged prior to this output, all responses are within 1 second)
Apr 21 09:46:47.243 UTC: //809744/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:X.X.X.200:5060 SIP/2.0
Via: SIP/2.0/UDP X.X.X.199:5060;branch=z9hG4bK982CF26EE
To: <sip:X.X.X.200>
Date: Thu, 21 Apr 2016 09:46:47 GMT
Call-ID: CC5A9731-6DC11E6-874FEC69-4594C0FA@X.X.X.199
User-Agent: Cisco/v14 r1/ptn02
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:X.X.X.199:5060>
Content-Length: 0
Apr 21 09:46:47.743 UTC: %SIP-5-DIALPEER_STATUS: VoIP dial-Peer <81> is Busied out
Apr 21 09:46:47.899 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:X.X.X.200>;tag=957248771
CSeq: 101 OPTIONS
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Content-Length: 0
ptn02# sh dial- voic sum | i 125
1250   voip  up   up             [2-7].......$      4  syst ipv4:X.X.X.200             busyout
1255   voip  up   up             [2-7].......$      5  syst ipv4:X.X.X.72              active
Any idea is more than welcome
8 Replies 8
MOHIT SINGH
The operation status of dial peer is still "UP" so i don't think router will use another dial peer even though keep alive is "busyout". Apart from Options Ping if you want to use other dial peer for failover then you can change SIP to use TCP (session transport TCP) or/and configure "retry invite 3" under "sip-ua".
Hi Mohit,
thanks for quick answer. As I know, the "sip options-keepalive" technique is mainly used for redundancy support, so once the dial peer is busied-out, the second dial-peer should be matched immediately to minimize the delay. So that's why the "busy-out" state was introduced - as described in e.g. https://supportforums.cisco.com/discussion/12514401/will-keepalive-option-be-available-voip-gateway-without-cube or https://supportforums.cisco.com/document/12538231/ios-sip-options-ping
I can remove the "sip options-keepalive" but then the dial-peer goes down only when the new call setup is requested - and it's too late and takes some time due to "retry invite" mechanism.
I am not sure when Options Ping will mark Operation state as "Down". You can enable TCP for SIP if you don't want delay due to retry invite. If primary server is not available then TCP handshake will fail and calls will be routed using next dial peer.
as I understand, Option Ping just changes the keepalive to busyout but the Op state remains Up. But that busyout should cause that the dial-peer won't be selected.
Anyway, your suggestion would probably solve the issue ;)
But I still don't understand that behavior - why the dial-peer gets busyout if the sip option gets responses? Why the second dial-peer 1255 is not selected? May it be related to IOS (bug?) ?
Thanks for your time, really appreciate it.
Can you share complete logs for dial peer busyout and call failure? For the calls not selecting 1255 i would need below debugs
debug ccsip message
debug ccsip error
debug voip ccapi inout
sorry for delay, the issue didn't happen until now.
Finally it happened yesterday so the trace is attached. Strange is that the issue happens any time.
In the logs i can see dial peer was marked busy out due to max retries but the Options Ping was sent only once.
Apr 26 15:39:44.161 UTC: //831433/000000000000/SIP/Error/act_sent_OODoptions_wait_response:
 Out of retries
+ Why have you configured "monitor probe icmp-ping" under same dial peer when you have SIP options enabled? I believe they both can mark dial peer down. If you are not using "monitor probe icmp-ping" then can you remove it and test.
http://www.cisco.com/c/en/us/td/docs/ios/voice/command/reference/vr_book/vr_c3.html
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/vb_book/vb_book/vb_9321.html
finally got some new traces, see attachment. I removed the "monitor probe icmp-ping" command from dial-peer, but the dial peer still gets to busyout state, see attachment.
Thanks for your time.
