VoIP over VPN using QOS Tunnel
lvaike
All I have set up a VPN tunnel on a Cisco 871 from a remote site to our VPN hub.
The remote site has 1 Vlan with both Phone and PC on that VLAN I have attached the remote end config. Voice calls work however I cant guarantee that my QOS is working for voice traffic. I have 512kbps link to internet.
my questions are:
1) is voice traffic being distinguished from data traffic?
2) Should I create separate vlans for voice and data.
ip cef
ip dhcp pool mypool
network 10.1.245.112 255.255.255.248
default-router 10.1.245.113
netbios-name-server 10.1.80.59
netbios-node-type h-node
dns-server 10.1.80.59
domain-name xxxx.com
lease 14
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key Telecom address xxx.xxx.xxx.xxx
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to VPN-HUB
set peer xxx.xxx.xxx.xxx
set transform-set ESP-3DES-SHA
match address 100
class-map match-any Call-Setup
match ip dscp cs3
match ip dscp af31
class-map match-all Voice
match ip dscp ef
policy-map LLQ
class Voice
priority 128
class Call-Setup
bandwidth percent 2
class class-default
fair-queue
policy-map Traffic-Shaper
class class-default
shape average 512000
service-policy LLQ
interface Tunnel0
ip address 10.250.15.2 255.255.255.0
ip mtu 1420
qos pre-classify
tunnel source FastEthernet4
tunnel destination xxx.xxx.xxx.xxx
tunnel path-mtu-discovery
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description Connection to Internet$ETH-WAN$
!Registered IP address
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip tcp adjust-mss 542
speed 10
half-duplex
service-policy output Traffic-Shaper
interface Vlan1
description Connection to LAN$ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.1.245.113 255.255.255.248
ip tcp adjust-mss 1452
router rip
version 2
network 10.0.0.0
paolo bevilacqua
you don't need and can't even use separate VLANs on the VPN. Your QoS config appears correct and should do the best possible.
Only, you don't need ip tcp adjust-mss 542 under FA4. You could use something like 1380, but on VLAN1 instead.
The only other improvement I may think, if this is an ADSL circuit, use an 877 instead so you can see the real circuit and avoiding the need for a QoS childed service-policy.
Please rate if it helps!
