Voip Solution
koralul2000
I'm kind of new in this domain so I'd like to have an advise from someone more advanced. What cisco solution is the best for terminating voice calls with a high precent of G729r8, g729br8, g729r8-prietf codecs to an ISDN trunk?
Thank you.
paolo bevilacqua
You can use a 2901 for that, with the adequate interface and PVDM3 resources.
You should workwith a reputable consulant, or certified Ciaco partner, for good results.
Thank for your answer Paolo.
But for a small application SIP->ISDN(~30 simultaneous calls) is suitbale a Cisco 2610 Series configured with a WIC-1B-S/T?
A 2610 with a WIC-1B-S/T this is for DATA networking using BRI not PSTN access with 30ch PRI
You would need the relevant DSP chip and an MFT-E1 on the 2610
Alex
Regards, Alex. Please rate useful posts.
The 2600 are really obsolute now.
You should use an ISR G1 or G2 routers.
