VOIP support in 1721 and 1841
shoebwk
I have a following scenario as shown in the diagram.
I want to make sure will 1841 support VOIP traffic.?
SK
5 Replies 5
thisisshanky
Level 11
Level 11
With your scenario it should work, as you are not terminating any Voice T1s or FXO/FXS lines on the 1800 or 1700 series router. THe Siemens products will convert voice into packet and transported over the link. This should definitely work.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for the support,
Could you guide me to setting up QoS in both the router as i am told that without QoS the Voip will not work.?
SK
SK,
You should also open up ports on the firewall (I am not sure what ports are used by Siemens VOIP system).
Depending upon the type of link, refer to qos srnd for type of qos required. (look for enterprise qos srnd)
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_program_category_home.html
Sankar
PS: please remember to rate posts!@
Sankar Nair
Do i require to apply QoS on all the routers?
You should apply QoS on every equipments where voice packets pass by.
S?rgio Pinto
