voip - switching
dave dave
hi! does anyone know what shd be configured on the cisco switch port if i would to use a polycom(c x600) ip phone with 2 ethernet port for microsoft communicator? One port will be connected to the switch and another port to the pc. How;s the voice vlan and qos shd be done for this case? how about polycom with single ethernet port? whats the different in config? does anyone has a working sample config to share with?
thx
Marwan ALshawi
wiht cisco IP phone the phone negotiate the voice vlan with the switch uinsg CDP
CDP is Cisco protocol and becuase of this i dont think you can use the voice vlan
however what you could try setup the interface as trunk interface and allow only voice vlan and PC/data vlan
in the phone if you can enter/configure the vlan ID manully then put it as the voice vlan and the PC/data vlan make it as a native vlan in the switch ( untaged ) use the requried QoS marking for QoS polices
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080891554.shtml
or you can consider LDPMED:
https://supportforums.cisco.com/thread/2065287
if helpful Rate
