Voip using cisco 2800
plight001
OI have a cisco 2800 and need to achieve voip on port 5060, mypbx ip 10.1.0.191 and cisco ext ip 41.215.180.46. Please help
6 Replies 6
Dan Lukes
Inappropriate in Feedback forum, see description. Moved.
Thanks Dan was in a hurry and on a mobile
Jaime Valencia
OK, in first place you need to configure CME on your ISR (refer to the CME admin/config guide for any task), then, I'm assuming the other end supports SIP trunks, so you'll need to configure your SIP DPs to it. IP Phones dial DNs, not IPs.
java
if this helps, please rate
Thanks let me try that. Firstly what is ISR?  Is it the router?
ISR = Integrated Services Router
java
You may want to ask this question in the appropriate section "Routing and Switching" since your question is related to NAT and not Cisco Voice.
Guys in the IP Telephony community have more knowledge in Cisco Voice and UC stuff than in Routing/NAT.
