VoIP / virtual PBX
andrewpaulsen
I'm Having an issue determining how to setup my configs for a VoIP solutions here is what i have.
cisco 2811 with a 3550 switch, the company i work for uses a virtual PBX hosted by another company. i have to install the 2811 with the 3550 and 20 cisco 7960 phones. I have done all the DHCP pools, the trunking and vlans and intervlan's . but the main issue is trying to figure out how to setup the telephony service or do i not need to as the host PBX server has all the configs store on it and the original way was just plug and play in a sense with just a few modifications?
If more details are needed i can provide.
Jaime Valencia
That is something you would need to find out within your company, if you have an ISR, you would configure CME
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
You need to find out whether they bought that equipment to configure their own CME, or just to provide connectivity for that hosted PBX, and then ask assistance from them to find out what you need to configure for the phones to work with them.
I would assume they want their own, but that's just my assumption.
java
if this helps, please rate
thanlks for getting back i actually was over thinking things when i posted this and found out a few things i was unaware of from the originator who also handles are platform
