05-28-2013 01:50 AM - edited 03-16-2019 05:32 PM
Hi Guys,
I'm currently on a customer site to migrating from classic telephony to ToIP.
I have a 2901 router (MGCP), with two vwic3-amft-t1/e1 card.
The provider give me two E1, one with 30 channels and the other with15 channels.
I'm testing with the 30 channels E1 on my E10/0/0 port.
When I unplug the E1 cable from the old PABX, and plug into my 2901, nothing happens : controller E1 stay down and amber alarm led is fix.
If i unplug the cable from the E1 port of my 2901 the amber alarm light stay fix too.
The E1 works on the old PABX ...
You can fin a show controller E1 just there :
GW_Mions#show controllers E1
E1 0/0/0 is down.
Applique type is Channelized E1 - balanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (438 seconds elapsed):
2 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 438 Unavail Secs
E1 0/1/0 is down.
Data in current interval (437 seconds elapsed):
1 Line Code Violations, 0 Path Code Violations
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 437 Unavail Secs
You can find the 2901 config attached.
Thanks for your help !
05-28-2013 01:53 AM
By the way, the mgcp registration seems to be good :
GW_Mions#show ccm-manager
MGCP Domain Name: GW_Mions.scamer.fr
Priority Status Host
Primary Registered 172.16.124.8
First Backup Backup Ready 172.16.124.7
Second Backup None
Current active Call Manager: 172.16.124.8
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 08:49:36 UTC May 28 2013 (elapsed time: 00:00:08)
Last MGCP traffic time: 08:49:36 UTC May 28 2013 (elapsed time: 00:00:08)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 172.16.124.8
Current Link State: OPEN
Statistics:
Packets recvd: 1
Recv failures: 0
Packets xmitted: 6
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 1, port 0
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1369662864-f2df81df-8ed0-4cdc-a145-24119ef87094
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
no network-clock-participate wic 1
end
no network-clock-participate wic 0
end
IOS version is :c2900-universalk9-mz.SPA.152-4.M2.bin
