Need help setting up a 6921 ip phone on a 2901 Router
Good day,
I am a new Network administrator and do not have allot of experience, so any help would be appreciated thanks.
I am trying to setup a 6921 cisco ip phone on a 2901 router but the phone says "phone not registered"
i did setup the dhcp pool and loaded the telephony service but not to sure if i got the firmware of the phone on the router correct?
ip's has been setup and port has been unshut.
please help thanks.
ronpatel
Level 8
Level 8
Please send us the config. Config will help us to find the problem.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Router#sho run
Building configuration...
Current configuration : 1899 bytes
! Last configuration change at 08:32:05 UTC Tue May 28 2013
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.13.220 192.168.13.254
ip dhcp pool phone
network 192.168.13.0 255.255.255.0
default-router 192.168.13.254
option 150 ip 192.168.13.254
voice-card 0
license udi pid CISCO2901/K9 sn FCZ162620N7
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.13.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/3/0
voice-port 0/3/1
mgcp profile default
gatekeeper
shutdown
telephony-service
max-ephones 24
max-dn 72
ip source-address 192.168.13.254 port 2000
system message test
load 6921 SCCP6921.8-5-3-0.loads*
max-conferences 8 gain -6
dn-webedit
transfer-system full-consult
ephone-dn  1
number 1167
label 1167
description User 1
name user 1
ephone  1
mac-address 1CE6.C799.362B
max-calls-per-button 2
username "user5" password 12345
type 6921
button  1:1
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
