vwic3-1mft-t1e1-e1 - Port stay Down, Alarm LED stay amber fix
Hi Guys,
I'm currently on a customer site to migrating from classic telephony to ToIP.
I have a 2901 router (MGCP), with two vwic3-amft-t1/e1 card.
The provider give me two E1, one with 30 channels and the other with15 channels.
I'm testing with the 30 channels E1 on my E10/0/0 port.
When I unplug the E1 cable from the old PABX, and plug into my 2901, nothing happens : controller E1 stay down and amber alarm led is fix.
If i unplug the cable from the E1 port of my 2901 the amber alarm light stay fix too.
The E1 works on the old PABX ...
You can fin a show controller E1 just there :
GW_Mions#show controllers E1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (438 seconds elapsed):
     2 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 438 Unavail Secs
E1 0/1/0 is down.
  Data in current interval (437 seconds elapsed):
     1 Line Code Violations, 0 Path Code Violations
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 437 Unavail Secs
You can find the 2901 config attached.
Thanks for your help !
By the way, the mgcp registration seems to be good :
GW_Mions#show ccm-manager
MGCP Domain Name: GW_Mions.scamer.fr
Priority        Status                   Host
Primary         Registered               172.16.124.8
First Backup    Backup Ready             172.16.124.7
Second Backup   None
Current active Call Manager:    172.16.124.8
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            08:49:36 UTC May 28 2013 (elapsed time: 00:00:08)
Last MGCP traffic time:         08:49:36 UTC May 28 2013 (elapsed time: 00:00:08)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/OFF
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  172.16.124.8
    Current Link State: OPEN
    Statistics:
        Packets recvd:   1
        Recv failures:   0
        Packets xmitted: 6
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 1, port 0
        Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1369662864-f2df81df-8ed0-4cdc-a145-24119ef87094
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 1
          Download Failed              : 0
          TFTP Download Failed         : 0
        Configuration Attempted        : 1
          Configuration Successful     : 1
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
no network-clock-participate wic 1
end
no network-clock-participate wic 0
end
IOS version is :c2900-universalk9-mz.SPA.152-4.M2.bin
