Wallmount for 6900 Phones
Noticed that the 6900 phones do not have mounting lugs for a standard wallmount. There's a kit available (Charcoal Locking Wallmount Kit for 6921 & 6941, CP-WMK-C-6900=), but I'm wondering if this is our only option. Anyone else wallmount these without the kit?
Nicolas Mansour
From the datasheet:
Dual-position foot stand The display is easy to view and the buttons and keys are easy to use; you can remove the foot stand for wall
mounting, with mounting holes located on the base of the phone.
The only disadvantage with the normal wallmount is that anyone can unplug the phone. The wall-mount option you mentioned has a lock.
