We are having issue in call forwarding option in Cucm. when we try to forward any call external DN, call is being answered but both party can not hear each other
vijay.gupta369
Hello Friends,
We are having issue in call forwarding option in Cucm. when we try to forward any call on external DN, call is being answered but both party can not hear each other.
1. internal forwarding is ok only problem with external forwarding.
2. we are using call manager 7.5 and we have Cube for exit the external calls.
3. it is an intermediate issue as well , some time it work well and some time does not well for each site , which are configured in this cluster.
Call flow ---- PSTN---(sip)-----CUBE-----(sip)----CUCM-----(phone)
5 Replies 5
Dennis Mink
This could be caused by a number of things. Most likely causes are:  inability to negotiate a codec and/or inability to route RTP between endpoints.
Can you provide  debug ccsip message output of a failed call to see what is going on.
cheers
Please remember to rate useful posts, by clicking on the stars below.
I called on this number 1-4122375117 and the call is getting forwarded to this number .91-4193327357.
Calling number - Skype
Called number - 1-4122375117
Call forward number  -91-4193327357
PFA all the logs of Cube. please let me know if you need any other thing.
PFA all the logs of cube. please let me know, if you need any other thing.
When you face the problem, please share the following
1. From CUBE, get the command show active call voice brief. Indicate the calling and called numbers
2. From CUBE Try to ping the IP and and ITSP using the right source IPs.
3. From CUBE, share the command show sccp connection
4. From CUBE, debug ccsip mess
5. From CUCM, try to get RTMT Realtime Trace
Please put the debug in separate file to be able to read it properly.
Thanks!!
