Web Access to CCME , nothing displayed after login as administrator
Support Albakom
Level 3
Level 3
hi,
some strange behaviour with a cme web page.
I access the page via <IP>/telephony_service.html.
I can login with the configured administrative credentials.
After that, the window appeared and nothing is show only a "View Window" in the left upper corner.
No menu, no links, nothing.
If I close the browser, reopen it and try to login with a normal Useraccount, the menu appears, I can click to all, made changes, save and so on.
CCME Version is 8.5 with IOS 151-3.T1.
I try to change the gui files, wihtout changes the same problem.
The command "file privilege 0" only works when there's a white screen on versions 8.8, 9.0, and 9.1 I think.
If the GUI only shows "View Window", it's neccesary to delete all the existing CME GUI files and reload them to the flash, after that re-configure the http path and restart http service, by doing "no ip http-server" and "ip http-server". And in extreme scenarios, I had to reload the router, and after that it should work.
Let us know if any of the suggestions worked.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
acampbell
Can you try adding this line to your config
conf t
file privilege 0
exit
then retest
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Jorge Armijo
Nothing of this works. A reload of the router I've not tried yet.
After reload it works!
