01-21-2010 10:24 AM - edited 03-15-2019 09:10 PM
What is the first callmanager express version with support the IP phones 6900 series
Solved! Go to Solution.
01-21-2010 10:28 AM
None, support will be on 8.X
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-21-2010 10:28 AM
java
01-21-2010 10:44 AM
Javalenc
what is the ios version i need load to my gateway 2821 to run CUCME 8.0
01-21-2010 11:14 AM
Hi there,
Just to try and fill Java's large shoes for a moment;
Cisco Unified CME 8.0 Supported Firmware, Platforms, Memory, and Voice Products
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme80spc.htm
IOS - 15.0(1)XA
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Hope this helps!
Rob
