What does "softKeySetIndex=1" mean?
hxmengmetro
Hi All,
softKeySetIndex=1 means "Hold", "Transfer" or "End Call"? Thanks.
Lou
Jaime Valencia
Neither, it does not represent a single softkey as the name implies (softKeySetIndex)
By default you get that when you're on connected state.
Hold, EndCall, Trnsfer, Park, Confrn
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thank you!
