05-27-2013 05:47 PM - edited 03-16-2019 05:32 PM
We are planning on upgrading to 8.6(2) and according to the documentation it takes 2-3 hours per server. We would like to know what features will be down while the publisher is down during the upgrade.
Jeff Mize
Solved! Go to Solution.
05-27-2013 10:13 PM
Yes
05-27-2013 07:13 PM
BAT, and any kind of admin changes will be down, only UFF will work.
Depending on if you have EM and other services with redundancy or not, they might not work.
05-27-2013 08:26 PM
Will Conference, Transfer, Hold and Music On Hold work while the Publisher is down?
05-27-2013 08:54 PM
Assuming you're not using the IPVMS from PUB, yes, otherwise, no conference or MOH
05-27-2013 08:59 PM
How can I tell if we are using IPVMS? Thanks for the input by the way.
05-27-2013 09:11 PM
Check your MRG and MRGL to see how that is configured
05-27-2013 10:12 PM
We have mrg's built on each subscriber. Would Transfer be available if the publisher is down?
05-27-2013 10:13 PM
Yes
05-27-2013 10:36 PM
One last question. So if we have MRG's built on each Sub, we should have Conference as well...correct?
