12-03-2015 07:09 AM - edited 03-17-2019 05:06 AM
Hi I want to set up a VoIP lab. But I want to replace router 2821 with 2811. If so, what function I will lose? Thank you
Solved! Go to Solution.
12-03-2015 07:27 AM
In terms of voice features there is basically no difference between these two. You can check their datasheets or comparison charts like below for details
http://www.cisco.com/c/en/us/products/routers/2800-series-integrated-services-routers-isr/models-comparison.html
Manish
12-03-2015 08:58 AM
If its CME or SRST you will find a difference in the number of phones you can support.
12-03-2015 07:27 AM
Manish
12-03-2015 08:58 AM
12-03-2015 09:01 AM
Thank you so much for your reply.
It looks like the the data sheet shows 2821 has 3 Onboard DSP Slots, and 2811 has 2
What is Onboard DSP Slots?
12-03-2015 07:35 AM
You'll also gain 1 RU.
