What is the difference between B2BUA and proxy in SIP protocol ?
Bahlul Guliyev
Dear all,
Can anybody explain me, what is the difference between SIP B2BUA and SIP Proxy?
Best Regards
Bahlul
5 Replies 5
Vivek Batra
Please check this recent discussion;
https://supportforums.cisco.com/discussion/12691841/sip-topolgy
- Vivek
Ayodeji Okanlawon
In addition to Vivek's reference..
A SIP B2BUA can both innitiate a request and then at the same time provide a response to requests. A B2BUA combines both the functionality of a UAC and a UAS. A UAC is a user agent client that innitiates a request and a UAS is a user agent server that generates a response to the request.
A proxy server relays requests and responses, A proxy most times just acts as a middle man between the client and the terminating server
Please rate all useful posts
Dear Ayodeji,
Thanks for explanation.
Best Regards
Bahlul
So it sounds like the B2BUA and the Proxy work in conjunction with each other? Would that be an accurate statement?
Technically they are different. Proxy functionality (stateful and stateless) is defined by RFC 3261, whereas B2BUA which is originated and implemented as a byproduct of advanced requirement and not standard defined.
