When I connect to anyconnect IPC receive local IP instead of VPN IP and so I get no Audio.
Muhammad Hayat
When I connect to AnyConnect IP communicator register with CUCM using local LAN IP instead of VPN IP and I don’t get any audio.
Any suggestion?
Aseem Anand
Did you try changing the network interface on the CIPC itself under preferences, network "Use Network Adapter to generate Device Name " ?
Aseem
