When will firmware SCCP9-2-2 for 8945 be available?
tore.skancke
Hi.
Currently the 8945 IP phone has busy trigger hard-coded to 2. According to bug
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq94796
this will be fixed in SCCP9-2-2 which is due out Oct 2011
Does anyone know which date it will be released? I'm about to set up some 8945 phones in a Contact Center where busy trigger 1 is mandatory so I would like to get my hands on the new firmware ASAP.
Best reg,
Tore Skancke
5 Replies 5
Jaime Valencia
You should direct this question to your Account Team.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
tore.skancke
In case anyone else is wondering...
According to the Development Team this firmware is expected to be available for download on October 25.
It is currently undergoing testing and verification.
Best reg,
Tore Skancke
Fabian.Flamme
So, 9.2(3) is out but still no possibility to change the busy trigger field.
We use 8.5.1
Any ideas?
Fabian
My understanding is that latest firmware offers  max calls/busy trigger of up 32, is this not what you are seeting?
Chris
I stand corrected, it supports 24/24 not 32, this was added in firmware 9.2.2
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/8941_8945/firmware/9_2_2/english/release/notes/8941_8945_922.html
HTH,
Chris
