07-03-2012 01:12 AM - edited 03-16-2019 11:58 AM
Where do I find out in Unity Connection 8.x whether I have the restriced or unrestriced version installed? I checked under various places in OS Adminstration, but did not see anything?
James
Solved! Go to Solution.
07-03-2012 03:28 AM
If you click About in the upper-right it will say the version. If it's the unrestricted version (i.e. encryption disabled) then it will also say Unrestricted. If you don't see Unrestricted then you're running the Restricted build.
Please remember to rate helpful responses and identify helpful or correct answers.
07-03-2012 03:28 AM
07-03-2012 11:30 AM
Thanks Jonathan.
