IP Telephony and Phones
watch here Journey banner_1
Labels
Hello All,Users are asking for a simple feature which was available on their old PBX and i cannot find it anywhere here.Phone A is on an important call, Phone B is calling Phone A and hears ringing ringing ringing but no answer, he doesn’t know that ...
I am trying to undertand the function of CMG field when we create a Route List i.e what impact does the RL CMG have on the call path.My example:VM Route Pattern: 408-123-4567CUC_RL with CMG_DefaultCUC_RG which contains following two SIP TrunksTrunk_A...
Hi,Does it make a difference whether you have TrunkA and TrunkB both in the same RG COMPARED to each Trunk in it's own RG. I am trying to find this out cuz I will have two SIP Trunks going from CUCM cluster to a Unity Connection Cluster.  Would it m...
Hello,I am trying to make an external bell ring at the same time when a Cisco VoIP phone is called.  The environment we are in is very loud and the ringer was great before we implemented VoIP.I have the external bell connected to a FXS port off of my...
Hi All,       Need you help in choosing ios image for router 3825 support outbound call from sip trunk.  Our team is not able to configure  Router 3825 router with current image( c3825-advipservicesk9-mz.150-1.M7) for outbound call.We need  to enable...
is there is a way to unify the PIN that is used in extension mobility with the PIN used in the Unity Connection?so when i change the PIN of one application either the extension mobility or the Unity Connection to affect the other application.
