Where is sample configuration of EAP pass-through enable switch?
mhiyoshi
Level 3
Level 3
Dear support all,
I have read the following document below so some devices can be possible to function EAP pass-through however there is not any related configuration example. So I appreciate if you can let me know any related URL. thank you.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_3_e/consolidated_guide/b_1523e_consolidated_2960x_cg/b_consolidated_152ex_2960-X_cg_chapter_0101101.html
*EAP pass-through is supported on Catalyst switches that have 802.1x disabled. When EAP pass-through mode is active, the authenticator relays the EAP packets to and from the 802.1x frames and the RADIUS packets.
Best Regards,
Masanobu Hiyoshi
0 Replies 0
