Which Version of CME am I running, and how to upgrade it?
Geo Gon
Hi all,
Based on my config, I'm running CME 3.3, im pretty sure, based on my IOS version, it should be a newer CME.
Can you please take a look on my config and tell me if its right or wrong, and what should I do to upgrade it?
sh telephony-service
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
sh ver
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(25f), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 16-Aug-11 07:46 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Router2800 uptime is 1 hour, 29 minutes
System image file is "flash:c2801-adventerprisek9-mz.124-25f.bin"
Start by looking at these 2 links
1) Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
2) Cisco Unified Communications Manager Express System Administrator Guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
Your GUI file determines the version that you are running
Alex
Regards, Alex. Please rate useful posts.
6 Replies 6
paolo bevilacqua
To update you need a support contract, but preferably contact a reputable consultant, or UC certified Cisco partner.
Thanks for you reply Paolo,
I only using it as a lab for my CCNA Voice exam.
What it triggers me if the fact that by the version of my IOS, it should be a higher version of the CME.
Do know how can I upgrade it? What do I need to do so?
Thanks again
You can search 'upgrade CME', there are many many threads about that.
hey,
i need support for Ip phones configurations
we have ip phones with extension from 683, 684 & so on
so whenever we receive call from above extension, we should not make transfer, make conference or place new call
how is this possible?
Geo Gon
Hi guys,
I have now upgraded my CME 3.3 to CME 8, but when I do a sh telephony, still says that the version is 3.3
Can this IOS
Actualy support a higher CME version?
Thanks again
Alex
