which version of CUCME contains firmware 8.5.2
Support Albakom
Level 3
Level 3
want to upgrade an older CUCME to version 8.5. But the phones firmware is something about 8.2 and cannot direct upgrade to 9.1 firmware. must set to 8.5.2 before. whch CUCME Version in Cisco Download Software Page contains this firmware?
In CUCME 7.1.0.1 is firmware 8.4.1 and in CUCME 8.0 is firmware 8.5.3.
But theres no version between? How to resolve this? Phones are 7940/7960, 7970, ATA186 and 7912.
Rob Huffman
Hi SA,
I don't believe any of those listed phone models fall under that restriction. You will need to look
at this info for 7940/60/70
Note You cannot upgrade to firmware release 8.1(2) directly from firmware release 8.0(10) or an earlier release. You have to upgrade to firmware release 8.1(1) first, then upgrade from release 8.1(1) to release 8.1(2).
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/firmware/8_1_2/english/release/notes/796040_812.html
Cisco Unified IP Phone 7960G and 7940G Release Notes for Firmware Release 8.1(1) (SCCP)
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/firmware/8_1_1/english/release/notes/796040_811.html
Here is the path for the individual CME .zip files for phone firmware;
Products
Voice and Unified Communications
IP Telephony
IP Phones
Cisco Unified IP Phone 7900 Series
Cisco Unified IP Phone 7940G
Skinny Client Control Protocol (SCCP) Software
8.1(1)
cmterm-7940-7960-sccp.8-1-1.zip
then
Products
IP Telephony
IP Phones
8.1(2)
cmterm-7940-7960-sccp.8-1-2.zip
Cheers!
Rob
Will try 8.1.1 for 7940/60.
But for 7970 I think I need 8.5.2, because phone says after trying upgrade "Auth fail".
Rob Huffman
Hi SA,
Yes, you are most correct my friend I was wrong about
the 7970, sorry about that. Here is the required info for that model;
To download and install the firmware, follow these steps:
Procedure
Step 1 Go to the following URL:
http://tools.cisco.com/support/downloads/pub/Redirect.x?mdfid=278875240
Step 2 Log in to the Tools and Resources Download Software page.
Step 3 Choose the IP Telephony folder by clicking +.
Step 4 Choose IP Phones > Cisco Unified IP Phones 7900 Series.
Step 5 Choose your phone type.
Step 6 Choose Skinny Client Control Protocol (SCCP) Software.
Step 7 Choose 8.5(2) under the Latest Releases folder.
Step 8 To download the SCCP firmware for the Cisco Unified IP Phone, click one of the hyperlinks and follow the prompts:
For Cisco Unified CallManager 4.2 and earlier (firmware files only):
cmterm-7975-sccp.8-5-2.zip
cmterm-7970_7971-sccp.8-5-2.zip
cmterm-7945_7965-sccp.8-5-2.zip
cmterm-7942_7962-sccp.8-5-2.zip
cmterm-7941_7961-sccp.8-5-2.zip
cmterm-7911_7906-sccp.8-5-2.zip
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852.html
Cheers!
Rob
downloaded 8.5.2 and 8.1.1 and succesfully installed. works fine. thanks.
