While in SRST (SIP Phones) it takes 12 seconds for a transfer to complete
MICHAEL CICCONE
Hello all, looking for some help.
When I'm in SRST Mode (all SIP Phones) it takes 12 seconds for the phone I want to transfer to to start ringing.  I press Transfer I get dial tone right away, I dial my extension then I have to wait 12 seconds before it will connect.
Any ideas as to why this takes so long?
Here is my SRST config:
voice register global
mode esrst
system message FALLBACK NET DOWN
max-dn 100
max-pool 100
voice register dn 1
number 8421190
shared-line
voice register pool 1
id network 0.0.0.0 mask 0.0.0.0
session-transport tcp
no digit collect kpml
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 2
id mac 0041.D293.EAA6
number 1 dn 1
voice register pool 3
id mac 00DA.5527.79FD
number 1 dn 1
voice register pool 4
id mac 00DA.5527.28A7
number 1 dn 1
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
max-ephones 75
moh enable-g711 "bootflash:SampleAudioSource.ulaw.wav"
sip-ua
retry invite 2
retry bye 1
timers expires 60000
timers connect 1000
timers buffer-invite 800
registrar ipv4:10.7.53.1 expires 600
reason-header override
Jaime Valencia
By any chance do you have any overlap in your dial plan?
java
if this helps, please rate
Jonathan Unger
Level 7
Level 7
Hi Michael,
Under your voice register pools the command "no digit collect kpml" is most likely causing your issue. In order to have SIP phones send their digits to the SRST gateway one by one without waiting the inter-digit timeout delay use the following command under each voice register pool.
"digit collect kpml"
Then try re-registering your phones to SRST and see if the issue is resolved.
Let us know if this helps!
Please rate helpful posts!
I know it's a quite old threat.
Got the same issue with a CME 12.0 and SIP (7841, 8821). With digit collect kpml (default settings) the SIP-phones are not able to transfer calls anymore. There was no changes done on the CME.
Changing the pool to "no digit collect kpml", transfer is working but with10sek delay until dialing.
Altering the interdigit timeout without success.
Any ideas?
Norbert
I have this problem too ... have you gotten any feedback?
