Why my dial-peers do not work. CUCM 7.1.3
I have some dial peers, one for local calls, one for national calls, and another one for international calls, I want local calls to go out by 0/0/1:0 port,
and National/international by 1/0/0:0
here are the dial peers.
dial-peer voice 1000 pots
destination-pattern 09........
direct-inward-dial
port 0/0/1:0
no register e164
dial-peer voice 1003 pots
destination-pattern 0901T
port 1/0/0:0
prefix 01
dial-peer voice 1004 pots
destination-pattern 0900T
port 1/0/0:0
prefix 00
but everytime o run the command "show dialplan num" I got this,!!!
show dialplan num 090014542345647
Macro Exp.: 090014542345647
VoiceEncapPeer1000
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `',
        tag = 1000, destination-pattern = `09........',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
show dialplan num 09014448110711
Macro Exp.: 09014448110711
VoiceEncapPeer1000
        description = `',
        allow watch = FALSE
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 1000, Admin state is up, Operation state is up,
        Outbound state is up,
----> Everycall is going out by the Dial peer 1000 <----
I've tried using this dial peer instead   "destination-pattern 09........"
      destination-pattern 09T
      direct-inward-dial
      port 0/0/1:0
      no register e164
And got this!!!!!
     show dialplan num 090013334444444
     Macro Exp.: 090013334444444
     No match, result=1
Even having the destination-pattern 0900T
Could you please help me to improve this? Y' this do not work as intended?
INFORMATION
IOS: Version 12.4(24)T4
Router Model: Cisco 3845 (revision 1.0)
Regards.!
try to change Dial peer 1000 to
destination-pattern 09........$
have you checked that the port 1/0/0:0 is up ?
also try to use this pattren ! not sure if this is the issue but just give it a go
destination-pattern 0901.T
port 1/0/0:0
prefix 01
I forgot, every Dial-Peer has the command "no register e164"
Like this!
port 1/0/0:0
prefix 01
no register e164
thanks
port 1/0/0:0
prefix 01
