Wireless Headset for Cisco IP 7941
adorkable
I'm trying to figure out which wireless headset to buy as a gift for someone who uses Cisco IP 7941 at work in a call center.
Not sure how the Cisco phone works, but they are currently using a wired headset that automatically pick up calls without having to lift up the reciever or press the headset button on the phone base. I was wondering which wireless headset would be able to do this.
Thanks in advance!
6 Replies 6
Chris Deren
Any of the plantronics headsets work well. Make sure you get the hook switch adapter as well so that the headset will not require a lifter.
http://www.plantronics.com/us/partners/cisco/
HTH,
Chris
I had read somewhere that the hookswitch adapter isn't compatible with the 7941. But it would be great if it does work.
Joseph Martini
Plantronics has some nice ones (http://www.plantronics.com/us/category/office), may can be ordered with a handset lifter too.
HeadsetsDirect
The following Cisco compatibility guide will help and is always being updated:
Plantronics Headsets for Cisco Phones
-Wayne
Yungi Chu
There are many compatible Plantronics, Jabra as well as GN Netcom Wireless Headsets, This page has many compatible models for Cisco 79xx:
http://headsetplus.com/category99_105/index.html
I'd recommend the Plantronics CS540, W740, Jabra Pro 9450, or Jabra Pro 920.  I personally use the Jabra Pro 9450 and I love it!
