Wireless IP Telephone and Cisco 7945 Phone
damiranz20
Dears,
Good Day!
I just want to ask if this is Possible.
I have my Cisco 8821 Wireless IP Telephone and Cisco 7945 Series.
I just want to ask what is the additional configuration to make it both ringing at the same time.
I already configured like this but still
** For 7945 Config **
ephone-dn 5 dual-line
number 5616
label 2155616
description Test
name Test
corlist incoming calls-allowed-all
ephone 5
no phone-ui speeddial-fastdial
no multicast-moh
mac-address XXXX.XXXX.XXXX
type 7945
button 1:5
*Wireless Config **
voice register dn 1
number 5616
name Test
voice register pool 1
busy-trigger-per-button 2
id mac XXXX.XXXX.XXXX
type 8821
number 1 dn 1
dtmf-relay sip-notify
voice-class codec 1
username (Ext) password (Ext)
description Test
Thanks and & Regards,
Mike
HARIS_HUSSAIN
With Above Config if both phones are registered and you dial no 5616 both phone should ring.
Another option is you configure a different number for each phone and then define Hunt Pilot Number with broadcast as hunting algorithm to ring both phones when hunt pilot is dialed.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Hi Harris,
Thanks for your suggestion.
It will ring one at a time.. sometime the call was received by wireless 8821 sometime on 7945 IP Telephone.
We cannot configure the voice hunt since the user is using only one Telephone Extension on both Telephones.
Kindly Help, your immediate response is highly appreciated.
Any possible solution please. Thanks a lot.
Hi haris,
Any possible solution? or additional Configuration?
Michael
