Wrong caller id on IPphone
waqas sardar
Hi Team,
When we call from HO IPphone (043673607) to full pstn number on an other HO IPphone (044384808), the cli shows DR PRI pilot number (037168888) instead calling HQ DID number (043673607).
Mobile calls are working fine.
Please find the attached isdn q931 debug.
Jaime Valencia
There is no attachment, look at your debug, if you send the wrong ANI in the setup message, then it's something you need to fix in CUCM. If you send the right ANI in the setup message, but the other end sees something different, then discuss with your telco why they're changing the ANI.
java
if this helps, please rate
@Jaime Valencia
Please find the attached debug.
ANI is correct but it seems channel issue "Requested circuit/channel not available".
Also previously routlist SLRL was registered with DR cucm and by unchked the "Run On All Active Unified CM Nodes" it registered back to the HO cucm.
