wrong extension in corporate directory
Abhishek Singh
Hi ,
A very small issue here and probably i have the answer but wanted the confirmation on it.
Problem Description : A user extension 62xx has being configured and on calling and other purposes it shows the correct ASCII prompt on the phone screen as well for the same 62xx. But when the user is being searched on the corporate directory ( through my own ccmuser page >> directory ), it has the extension as 62xx and ldap extension 63xx( which is wrong ) ( note  : we dont have the ldap integration configured here ).
Clicking on that extension , it asks for login and password, and does not take my credentials.
How do we change this incorrect information on the corporate directory ?
Whatever level you reach getting better never stops -- Sachin Tendulkar
acampbell
CCMAdmin
User Management-->End Users
Search for the user you want to fix
Change the "Telephone Number" to the correct value
Save
Updating the directory can take some time so be patient
Alex
Regards, Alex. Please rate useful posts.
acampbell
CCMAdmin
Save
Alex
hehehehehe..so funny.. just got it maself but full on 5 for being there always.. you are the man acampbell
